I've switched back from a custom OS and moved to the most modern standard OS that my truck can use (12212156). Here's what I've done so far:Please take a look at the image of the problem, the tune and the logged data. I realize that I also have a spark/KR issue that needs to be addressed. Note: this is for a 2000 Yukon XL with an LQ4, a 200/206 cam running 87 Octane. Everything about the stock truck tunes are set up to not use PE. Also, when PE was disabled, the MAF calibration was at least maintaining about 14.6:1 AFR.
- Calibrated the VE table for Stoic (trucks are set @ 14.68 vs. 14.63 for cars BTW)
- Calibrated the MAF (with {B0120} change over to go exclusively to MAF for 400 RPMs)
- reset the MAF (with {B0120} change over to go exclusively to MAF for 4000 RPMs) & verified that setup will track stoic nicely to about 5,600 RPMs (here's where the problem starts)
- Attempted to enable PE (see attached tune)
- Commanded VE obediently goes to 12.0 (set as test value initially, see attached file) and WB02 (using PLX analog on Aux Voltalge input 1) gets worse rather than better when PE is commanded.
Thanks to all,
Steve
PS: this boy needs help!
