Page 4 of 4 FirstFirst ... 234
Results 31 to 37 of 37
Thread: Anyway to fool 411 PCM into thinking its connected to 4L60E for TCC operation?
  1. #31
    You can try playing with the P1810 processing enabler, see if that makes any difference...
    The manual says the PCM will command a D4 shift pattern, but it doesn't say if it will apply the TCC.
    If you can somehow rig up N,R,P signals from the manual lever position, then it would work properly:
Name:	4L60E manual valve logic.png
  2. #32
    You could do something simpler:
    let the 4th gear pressure switch apply the TCC... i.e. the standard 700R4 circuit of 4th gear switch (NO) in series with brake switch (NC);
    you could then run with a manual trans segment in your PCM.
  3. #33
    Oct 2008
    I tried to use the 4th gear switch but it locks too soon really lugs the engine. 3200rpm stall converter. Thats why I want to get the PCM involved so I can control the mph it locks at.
  4. #34
    Ok, I see.
    Have you tried this:
    Try grounding just pins R (C2-17) and P (C2-18)... and leave pin N (C2-63) un-grounded.
  5. #35
    Oct 2008
    Yep when I took it for a test drive last night I had pins R and P grounded and a 660ohm resistor for the temp sensor. All the TSTATE09 bits were no. However it was strange that the GEAR PID went from being 3 in park to 1 when I started moving. Once again no lockup......
  6. #36
    The PCM might not be happy that there are no shift solenoids.
  7. #37
    Oct 2008
    I am going to make a connector that will allow me to put a resistor in place to simulate the solenoids. From pins E to T, E to S, and E to A I will use a 22ohm resistor. From Pins E to U and E to B I will use a 10ohm. from pins L to M I will use a 680ohm. From pins D to C I will use a 5ohm resistor. I will ground pins R and P. Do these resistor values look correct?
  1. 4L60E, Yank 3600 Stall, 3.42 gears TCC Apply/Release
    By 1fastgto in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 1st, 2010, 06:00 AM
  2. pcm swap any 411 will work?
    Last Post: May 25th, 2009, 11:30 PM
  3. TCC slipage on 4l60e
    By baughauto in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 14th, 2009, 05:03 AM
  4. 97 yukon, 411, 4l60e
    By W_D_R in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 17th, 2008, 05:23 AM
  5. 411 PCM's
    By joecar in forum Lounge
    Last Post: June 4th, 2007, 11:07 AM
