Results 1 to 3 of 3
Thread: Vane Positon Question
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default Vane Positon Question
    Hey guys,
    Tuning an LLY for a freind of mine. Got it running great and just going back to do some minor touch ups like dialing in the vane tables and such, but I do have one question.
    Is it normal/possible that if I'm commanding 26-28psi of boost on his stock turbo that I should see vane positions as high as 86% in my map...at higher rpm's?
    It's running fine and not barking at all but I just wonder if this is accurate... The other reason I ask is because the boost pressure PID is reading low, but maybe a glitch from logging too many channels?
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Jan 2008
    really depends on how much fuel you are putting through the cylinders to make the heat to drive the turbo.
    Jun 2008
    Yeah, but I guess what my concern is, is if anyone else has seen #'s like this in their logs and/or used those actual numbers in the vane tables when "dialing" in the vanes? I mean I guess it's safe otherwise the truck wouldn't be running so well.
    I figure it's about 400 rwhp or a touch less, and I'm only commaning 26-27psi of boost (actual). My boost pressure PID doesn't show that I'm making anywhere near that even though the truck runs great, so I'm not sure if that's a glitch or not. At 3,000 rpms and 120 mm3 of fuel it's showing 30psi map pressure, which is only 16psi actual boost... I know it's running better than that, but he also has 32 channels selected so that's why I was thinking maybe a glitch.
  1. Turbo Vane Target Position Question
    By dieselz28 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 21st, 2010, 12:38 AM
  2. vane %'s??
    By hondarider552 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 10th, 2008, 05:39 AM
  3. Min. turbo vane position?
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 9th, 2007, 10:56 PM
  4. VVT Vane position
    By killerbee in forum Duramax LLY
    Last Post: September 18th, 2006, 03:58 AM
