My car has decided to randomly start dying every so often. It only does it from idle and often during braking or turning, especially on inclines.
It doesn't seem to stutter out so much as just die like I reached up and turned the key.
Also during cruise when I let off the rpms hang then fall then rise, during this the timing is going from normal to 2* then back to normal. In my timing tables I'm not seeing any strange blocks that would explain the drop.
Any ideas?
