Results 1 to 10 of 11
Thread: V5 to V6 update using Autotap ATI V2 link
    Jul 2010
    Default V5 to V6 update using Autotap ATI V2 link
    Gentlemen,
    I bought an autotap ATI V2 software package 3 years ago that originally came with the V5 software (EFILive V5 professional), it has been registered and works fine. However, I decided to download the V6 software (from EFI webpage) because it has an additional feature of bidirectional communication which I would love to use (mainly for the CKP relearn).
    The problem is I need to now how and where to get the key to be able to register the V6 program.
    The new V6 version is: EFILive V6 exe V6.4.0 (Build 53) obdII dll V6.4.0. (Build 173)
    I would really like to get this activated as I am getting ready to fire off a iron block LS6 in my '78 Camaro.
    Thanks in advance for any direction you can give me.
    Hi LS,
    I notified Tech Support regarding a registration key.
    Also, you might also consider V7 software.
    Oct 2004
    Can you please email me (support@efilive.com) with:
    - The AutoTap serial number
    - EFILive V5 Pro registration key
    - Proof of purchase
    Andrew
    EFILive Crew
    Hi LS,
    I agree, V7 would be better than V6.
    Jul 2010
    I will be willing to purchase the V7 if that will be the way to go. I will provide the infomration for the V5 as soon as I get home tonight ( at work at this time). Let me know what I need to do to purchase the V7 upgrade.
    Thanks, Gentelmen.
    Quote Originally Posted by Leonard Sparks View Post
    Thanks, Gentelmen.
    There's no charge to upgrade to V7 if you already have an EFILive V5 or V6 Pro registration for your AutoTap cable.
    Just send the V5 registration details to paul@efilive.com or support@efilive.com and we'll send you back a V7 license.
    Then just download the latest V7 software here: http://forum.efilive.com/showthread....10-Pre-release
    And you're good to go.
    Jul 2010
    Thanks for your help, it loaded with no issues. I am blown away with all the features, sure is going to take getting used to.
    May 2012
    Dear EFILive Team,
    I am using the USB Autotap OBD II Diagnostic Scanner that came with the EFILive Software program. In the Software Registration Certificate instructions, I simply need to enter the registration key to activate AutoTap and EFILive software. My Software Registration Key : B1176CL7R82D, is not recognized by the EFILive Software. AutoTap Hardware Interface Serial Number: 0050263041. Please help.
    Regards,
    Bash
    Quote Originally Posted by bashturbo View Post
    Dear EFILive Team,
    Regards,
    Bash
    That serial and registration code is for the AutoTap hardware and software, not for EFLive. The AutoTap hardware shipped with a CD containing both EFILive and AutoTap software regardless of which software combinations you purchased. If you purchased the EFILive Scan Tool option when you purchased the AutoCal hardware, then they would have also received an EFILive registration key allowing you to use the EFILive Scan Tool software. If not, then you are only registered to use the AutoTap software. The EFILive registration key will have multiple segments separated by dashes like this: ABCD-EFGH-IJKL-MNOP.
    May 2012
    Hi Paul,
    Thanks for the reply. I now think that I can't use the Autotap hardware for tuning with EFILive, only for scanning purposes or can be used but with limited features only. I now understand why it goes to the "demo" mode when I tried tuning a corvette with EFILive. I thought at first that you may be able to supply me valid registration key or updated registration key but I guess that is not the way. What do you suggest now? Thank you so much for your support.
    regards,
    Bash
  1. Can I do anything with this AutoTap cable?
    By spoolin7 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2010, 04:03 PM
  2. Picked up a OLD AutoTap V1
    By N0DIH in forum FlashScan V1
    Last Post: March 1st, 2009, 09:06 AM
  3. Autotap
    By Grey Silver in forum Gen III V8 Specific
    Last Post: November 24th, 2007, 12:40 PM
  4. AutoTap and FlashScan V2
    By CGTMS in forum General
    Last Post: December 20th, 2006, 11:29 AM
  5. Need some help w/ AutoTap and my Ford...
    By ToplessTexan in forum Lounge
    Last Post: December 10th, 2005, 08:57 AM
