Page 4 of 4 FirstFirst ... 234
Results 31 to 37 of 37
Thread: $050B Error message
  1. #31
    Quote Originally Posted by jennett_c View Post
    ok. so whats going on with my v2
    Might need to be sent for repair...
  2. #32
    Run EFILive Explorer (EE) and goto the Config tab.
    Take a screenshot of this and post it here.
  3. #33
    Dec 2009
    Hey guys great news i think its fixed. i went back into the hidden menu as per blackys instructions but instead of checking my flash memory i pressed f4 once again and i erased everything. i then reinstalled all the efi live software. formatted the config.sys and data sys(internal and sd) went into scan and tune and programmed e38. went to truck and was able to black box read!!! Finally. Im so pumped now. just gotta try and flash now. will keep u guys posted. and thanks for all the help this far
  4. #34
    Dec 2009
    Success!!! just black box flashed by e38. Now im excited. thanks for the support everyone
  5. #35
    I don't know - yet.
    What is the modified date/time of the *.obj files in the folder:
    (for Vista/Win7) C:\ProgramData\EFILive\V8\Config
    (for Win2K/XP) S:\Documents and Settings\All Users\Application Data\EFILive\V8\Config
    Can you delete everything in that folder, then re-install the V8 software That will ensure new *.obj files are installed, just in case the installer decides the files already exist and does not overwrite them during the install.
    Then using V8 EFILiveS can And Tune->Black Box Settings, drop down the list under the [Program] button and select the "Format Config file system" option.
    Then configure the target controller you want to BBR/BBF on the [F4 Tune Settings] tab page.
    The drop down the list under the [Program] button and select "Program All Required Data (slower)" option.
    Meanwhile, can you tell me what the target controller is you're trying to read/flash and I'll check the install files here to make sure they are correct. There's a chance I may have included the wrong version *.obj script files in the release you're using.
  6. #36
    So you got it going...?
  7. #37
    Cool...
  1. Error message?
    By nathans1987 in forum Custom Operating Systems
    Last Post: September 2nd, 2009, 02:04 PM
  2. Error Message when trying to update
    By MN C5 in forum FlashScan V2
    Last Post: April 5th, 2009, 12:07 PM
  3. Error message formatting....
    By Lennart in forum FlashScan V2 BB Logging
    Last Post: March 27th, 2008, 11:34 PM
  4. Error message
    By Chevy366 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2007, 10:48 AM
  5. Error Message
    By TNRGreene in forum General (Diesel)
    Last Post: June 13th, 2007, 11:30 PM
