Results 1 to 6 of 6
Thread: ECU connectors?
    Aug 2008
    Default ECU connectors?
    Does anyone know where the ECU connectors can be purchased for the 2002-2005 2.2ltr Ecotec engine's? Need to build a Stand-alone engine harness and I'm not having any luck locating them...P11 ECM
    FLASHSCAN V2 & AUTOCAL
    Aug 2008
    Anyone? What about ECU Connector Part#'s?
    Apr 2008
    Regards,
    Odd Boy
    Aug 2008
    Quote Originally Posted by odd boy View Post
    I tried but he doesn't carry them & he's never dealt with a P11
    Aug 2008
    I found every connector & terminal I need for the 2.2 Ecotec 2002-2005 except this one: Delphi#(15326098) 9-Way F Global Terminal 150 Series Sealed
    Mar 2009
    Is that the coil/cam connector? I have all the connectors, if you need one I'll send you one.Give me a call, 909 910 3867, steve
  1. P10 connectors?
    By vectorbundle in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: August 31st, 2008, 03:14 AM
  2. Orange flashscan connectors
    By Gordy M in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2008, 07:56 AM
  3. V2 connectors for external devices
    By TFZ_Z06 in forum FlashScan V2 BB Logging
    Last Post: May 20th, 2008, 05:26 PM
  4. Orange Input Connectors?
    By Goldfinger911 in forum FlashScan V1
    Last Post: August 29th, 2007, 03:42 AM
