Results 1 to 3 of 3
Thread: 2007 Silverado E38 speed limiter
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Default 2007 Silverado E38 speed limiter
    Tuned a 2007 Silverado today with an E38. My first truck that new... Can't for the life of me get the speed limiter turned off - still comes in at 99mph...
    I noticed in the tables for speed limiter, there is one (H0156) that says it is controlled by "other module", not ECM - is that the problem? There are no limiter settings in the transmission controller...
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Jun 2005
    Well, search was my friend - found out where others said you have to set H0156 to "ECM" vice the stock setting of "other module"...
    go figure...
    GM EFI Tuner
    Dec 2007
    Quote Originally Posted by BLK02WS6 View Post
    go figure...
    Some GM designs take the speedo/VSS data from the ABS/ESP/EBC system. So if the ECM is set to "other module" it looks to a CAN based message for speedo/speed limiting etc.
  1. Speed limiter
    By RichardWebman in forum E37, E38 & E67 PFI ECM's
    Last Post: August 7th, 2009, 04:41 PM
  2. '07 Tahoe E38 speed limiter
    By JAY4SPEED in forum E37, E38 & E67 PFI ECM's
    Last Post: July 25th, 2007, 08:20 AM
  3. Speed Limiter
    By devil in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2006, 08:00 PM
