Results 1 to 7 of 7
Thread: Need 2010 T43 SPEEDO support across the board....
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Default Need 2010 T43 SPEEDO support across the board....
    Hey guys.... I'm really needing 2010 T43 parameters and speedo support especially for 2010 CAMARO and CORVETTE......
    Anyone else, please jump in here....
    Sooner the better!
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
    Feb 2006
    care to explain a bit more?
    do you mean for when u change the diff gears, having the kph to tps working properly?
    Feb 2006
    The problem is that I'm able to get the speedo working cause it's in the engine cal, not the trans.... I've also got the shift points scaled correctly by copying the data from earlier years of the same build.
    The issue is, that without the speedo segment of the trans cal, it causes some crazy torque management issues that make the car act really weird when you tip into the throttle....
    Hopefully we can make this work.
    Chuck CoW
    So you just need H0103? Because this is the one that went missing from the TCM sometime in 2009.
    Gotta love those GM software engineers...
    Feb 2006
    I would like the downshift pressure controls made available just like the upshift parameters.
    Happy to donate a 24 pack of redbull's for the cause
    Parameters for the diff change were added and will be in the next update. Thanks Chuck.
  1. Speedo calibration VSS in Scan not same as speedo
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 23rd, 2010, 01:47 PM
  2. Pontiac vibe 2009/ 2010 will EFIlive support it?
    By dexter in forum General (Petrol, Gas, Ethanol)
    Last Post: October 29th, 2009, 01:56 AM
  3. Thanks for 2010 Camaro support!!!
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: May 13th, 2009, 04:19 PM
  4. newb to the board
    By jlee41 in forum Lounge
    Last Post: February 16th, 2006, 02:42 PM
  5. Dash board
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2005, 04:47 PM
