Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: help with dsp5 install
  1. #11
    Jul 2010
    the pins are the longest ones is what chad at empire diesel told me and he said they should work fine buti have not chevked each possition to see if that makes a difference
  2. #12
    Jul 2009
    so the truck runs/starts/and has air w/o the switch installed?
    and the upgrade DSP OS hasn't been flashed yet?
    But when the pins are connected to the ecm it has a no start situation?
    first check your wires on your switch for cuts and abrasions...
    with an ohmmeter and your switch check each resistance (by turning the knob), should be around 25K,5.6K, 2.2K, 1K, 270R,
    25K being your factory operating resistance @ 5V.
    be sure its the grey connecter pin# 32,50.
    "If you are using a tune from another truck that is why the AC doesn't work, it is most likely a different System OS.
    If it does not start you could try disabling the VATS"- GMC-2002-DMAX ..... be sure of this! if your new to tuning it can be over looked!
    also try reflashing your stock tune file and repeating steps in the tutorial...
    05's can be quarky make sure your info and radio fuse is pulled when flashing of any sort
    read this tutorial and make sure you follow each step to the T. heres a link for that...
    http://download.efilive.com/Tutorial...%20LB7-LLY.pdf
  3. #13
    Jul 2010
    So I checked the switch with a ohm meter and nothing every setting was showing no reading so I guess the switch is bad and what would happen if I loaded a dsp tune with no switch
  4. #14
    Dec 2005
    Quote Originally Posted by chevyrida06 View Post
    It defaults to the main tables on the DSP5 tune file,
    www.mscservices.net
  5. #15
    Jul 2010
    Ok thanks for all the help hopefully a new.switch will.solve my problem
  1. Re-install of ecm/tcm-DSP5
    By BJJ-DURAMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 12th, 2010, 01:43 PM
  2. Help DSP5 Switch install
    By dieselthemeatbag in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 24th, 2010, 10:03 AM
  3. dsp5 switch install problems
    By jrad12381 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 27th, 2010, 05:03 PM
