Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 107
Thread: PCM Conversion Information
    Mar 2007
    Thank you all for the feedback - here's a copy of Revision 1.
    Please keep posting your additions or corrections.
    Thanks!
    Good deal
    Review comments:
    - might be easier to read if you split LS1A and LS1B(512K) into their own box rows.
    - LS1B(1M) and E37 have blanks for ckp/cmp.
    - should the early E40 have 24x/1x...?
    Aug 2010
    Hello turbo_bu,
    The chart is starting to take shape nicely. I don’t have software to edit PDF files, so I wasn’t able to make changes directly to the document and send it back to you.
    Rather than make a bunch of scattered comments, are you able to import the current information in the chart into a Word or Excel file ??
    I believe the Forum software accommodates posting Excel files (*.xls) directly. A Word file would have to be put into a zip folder and then posted.
    I could then make changes / suggestions directly, and save us both a lot of typing. Forum members would still be able to view the chart’s progress and comment, each time you reposted it.
    Regards,
    Taz
    Mar 2007
    I actually have it in Excel. Just figured everybody didn't have access to view it or edit it. I will post the Excel file on Monday (it is on work computer, not at home). Please help to correct or add anything that I am missing.
    Thanks for your help,
    Darren
    Mar 2007
    Here's the Excel file. Please feel free to add or make any corrections.
    Thanks,
    Aug 2010
    Hello Darren,
    Thanks for posting the Excel file. I added columns for PCM “Common Serv#” and “Common OS”. These are based on my experience; in my part of the world, and may not reflect global commonalities. Adding columns required some format changes – portrait to landscape, and some tight margins, to name a few.
    As you can see from the additions, my experience is primarily within the Gen III engine / LS1-B PCM.
    I corrected some misinterpretations from previous posts – mainly in the E40 information.
    Hopefully these additions are consistent with your original intentions when beginning this thread.
    The Gen IV (E38 / E67) and “Inline engine” (P10 / P11 / P12) information is a little sparse. Hopefully forum members with experience in these areas will take a moment to post some additional information.
    Regards,
    Taz
    Good flow guys
    Who ever edits the .xls: please bump the revision number in the filename.
    How do you tell Excel that you're entering just text and not math...?
  9. #19
    Aug 2010
    Hello Joecar,
    Updated the table in my previous post - there was a problem with one column. Excel format - in a cell ? Just right click while in the cell ... choose cell format ... allows for numbers, currency, etc. ... select the format you want for that cell.
    Regards,
    Taz
  10. #20
    Aug 2010
    Reposting the table ... caused a problem when I tried to edit it.
    Regards,
    Taz
  1. Replies: 12
    Last Post: July 20th, 2010, 07:14 PM
  2. Help Doing Fuel Segment Swap for my 98 to 00 PCM Conversion
    By edwardzracing in forum Gen III V8 Specific
    Last Post: May 25th, 2009, 05:09 AM
  3. Is this Motron 60 information worth anything?
    By Redline Motorsports in forum Gen III V8 Specific
    Last Post: September 2nd, 2007, 05:31 AM
  4. PCM conversion question.....
    By Rocketman69 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: June 22nd, 2007, 10:51 AM
  5. Tire Information
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: January 21st, 2006, 10:56 AM
