Results 1 to 4 of 4
Thread: 95 buick problem
    Aug 2010
    Default 95 buick problem
    Hi I have your trial copy for now. After I get it working I would like to get your full copy.
    But Im having problems and heres what they are:
    I purchased a aldl to usb cable from aldlcables.com
    I got all the drivers installed correctly
    When I try to connect it shows a green circle on the chatter but a red one on the max232 one. When I hit the connect it shows red things with some green lines too.
    Sorry Im a newbie to the obd1.5
    This is for a 95 buick riviera 3.8sc
    Thanks Shawn
    Hi Shawn, I moved your thread to the V4 section.
    Click the "Automatically detect chatter" button.
    Then, turn on View->Serial I/O, then click the "Start Aldl" button.
    Then copy the red/green text from the display (right click and select "Copy All") and paste them into this thread.
    How well does V4 do on the 3800?
  1. Holden Commodore VR Buick 3.8 V6 Tune?
    By strongarmz in forum General (Petrol, Gas, Ethanol)
    Last Post: August 16th, 2011, 01:02 PM
  2. 95 buick lesabre
    By danshot in forum EFILive V4
    Last Post: January 6th, 2010, 09:49 AM
  3. What Vehicle Def For a 94 Buick 3800
    By TucsonDirect in forum EFILive V4
    Last Post: January 4th, 2010, 09:58 AM
  4. ALDL Timing - Buick Roadmaster
    By 91olds98 in forum EFILive V4
    Last Post: March 30th, 2009, 01:29 PM
  5. Buick SC 3.8 ?
    By Boost in forum General (Petrol, Gas, Ethanol)
    Last Post: January 23rd, 2007, 03:14 PM
