Results 1 to 3 of 3
Thread: LS4 2 bar sensor
    Aug 2010
    Default LS4 2 bar sensor
    Hi, I have a fiew dumb quesitons. This is the first attempt using efilive for a gas engine. Normally I use efilive for diesel tuning and hptuners for gas (hp is what I started with years ago, old habbits die hard), I am trying efilive for gas because of their intigrated virtual ve table and auto 2 and 3 bar virtual ve tables.
    I am working on an 07 LS4 in a Monte Carlo. I shook out all the old parts and started over. It is now a Dart billet blocked, world LS7X headed 6.6l with a GT42r turbo, still FWD. I would like to use the 2bar virtual ve tables, under 2bar should meet our Hp goals. The stupid quesiton is do I need to install a 2bar map sensor, and if so any have a plug and play part #? Do I have to ditch the MAF? The 511.99 limit will be a problem? Is there anything tricky about tuning with efilive on the 2bar ve? This is not my first forced induction LS motor, but is is my first with out a custom os available or with out a real ve table. Any advice would help.
    Matt, welcome to the forum
    I don't know the specifics (I'm still stuck in LS1, old habits die hard), so here's my understanding (the little that I learnt):
    you need the 2 bar sensor, I don't know the p/n, you can keep the MAF since the limit has been raised, carefully read the VVE tutorial and guide.
    More info: VVE Setup Guide.
    Aug 2010
    I am in the same boat a you, old habbits do die hard, espically when we have great results.
  1. 2 bar map sensor
    By VYSSLS1 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 1st, 2011, 05:11 PM
  2. 3 Bar MAP sensor doesn't work with 3 Bar scaling!
    Last Post: April 27th, 2010, 05:21 PM
  3. 2.5 bar map sensor
    By 02SSLE in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 17th, 2010, 10:50 AM
  4. 3 bar map sensor
    By Delco in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 5th, 2007, 07:18 PM
  5. 2 Bar MAP Sensor
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2005, 12:28 AM
