Results 1 to 10 of 11
Thread: shift point for ls6 cam
    Nov 2007
    Default shift point for ls6 cam
    Well did my Second wot run with the new ls1 forgen motor and found out the ls6 cam doesn't like to be spun to 6k. Here is the log file and let know what you guys think. The guys with ls6 cam what do you have your shift points set at. I have 80e behing this motor.
    LS1B_0033.efi LS1-tune_0015.ctd
    2006 Trailblazer SS
    Twin Turbo 67 Chevy Truck
    SOLD Truck 2002 Chevy kb turbo t70 5.7l
    Nov 2007
    So guys what are you running for shift point for the ls6 cam??
    2006 Trailblazer SS
    Jul 2008
    Aaron:
    What type of heads and valve-train set-up do you have?
    I don't run that cam, but I can't believe the shift points would be that low..
    Nov 2007
    Quote Originally Posted by WeathermanShawn View Post
    Aaron:
    It forgen ls1 with 317 heads with 918 springs and stock rockers. The cr on the motor 9.2. It also has 80e behind it. All i know when get up around 6k doesn't feal right and feals like the motor is out of power to carry the truck to second gear. See above for the log file.
    2006 Trailblazer SS
    Something is wrong... is that the 2->3 shift were looking at...?
    Looks like PCM is short shifting for some reason;
    Try with D0961, D0962 set to 100%.... D0961 may be interfering with the 2->3 WOT upshift.
    Add the pids GEAR, TCCMODE, DYNAIR for your next log.
    LS6 cam should be good to a little over 6000 rpm.
    Are you getting a MAF DTC (you should)...?
    BTW: The 105kPa columns in your VE tables are not exactly equal.
    Nov 2007
    yea your looking at the right thing. I though i was in first gear and it was hanging up or didn't have enough power to shift into second. All i know is it doesn't feel right when get up close to 6k mark. I will add those pids and post back.
    2006 Trailblazer SS
    Apr 2007
    You have to spin the LS6 cam up to at least 6600 rpms to really take advantage of the power it makes. Power will peak about 6000 rpms and carry nearly flat to 6600 which it where it shines.
    Nov 2007
    Joecar,
    Still wouldn't shift out first so i let off. The wired part was 2nd to third pull where the rpm go up and drop little bit then go back up. Yes i sure getting maf dtc and have turned off in mil i think. I even turned down the shirt point to 5600 and didn't even shift at that. Here is my log file.
    2006 Trailblazer SS
    Quote Originally Posted by aaronr View Post
    If it won't shift 1->2 unless you back off, try setting D0940 to 5500 rpm.
    How big a stall do you have...?
    Quote Originally Posted by DrkPhx View Post
    From DrkPhx's comment (LS6 cam peak carries upto 6600 rpm), you should be able to shift that high.
    Set D0940,45,50 to 5500 rpm and see if you get it shifting...
    If you get it shifting, then raise either D0940,45,50 and/or D0910,15,20 until you get your desired shift points...
    You will have to raise the rev limiters B3303 above the shift points.
    How high can you spin your motor...? You can get the fastest ET if you shift as high as possible.
  1. Idle speed for LS6 cam
    By aaronr in forum Petrol / Gas
    Last Post: July 7th, 2010, 02:23 AM
  2. trouble with shift point tuning
    By hot-dog in forum Allison 5 & 6 Speed
    Last Post: March 23rd, 2009, 10:13 AM
  3. newwB has a question 6.0ls1 w/ls6 cam
    By REDDUCK381 in forum Gen III V8 Specific
    Last Post: January 6th, 2008, 12:52 PM
  4. Shift Point Adjuster not working?
    By Ninety8C5 in forum Gen III V8 Specific
    Last Post: October 16th, 2007, 03:09 PM
  5. shift point adjustment not working anymore
    By Alvin in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 2nd, 2007, 12:57 PM
