So, your FPR is with the fuel pump in the fuel tank (i.e. not at the fuel rail)...?
If so you need to use the B4001 IFR table from a stock LS1 file, see below (from www.holdencrazy.com see stock 2001/2002 Camaro/Firebird files).
The stock 2001/2002 IFR table requires fuel rail pressure to be at 58 psi; if yours is not 58 psi then you need to recalculate the IFR using your actual pressure (see the spreadsheet at the following link).
Calculating-Injector-Flow-rate
2001/2002 LS1 IFR B4001 (copy, then paste-with-labels):
Code:
LABELS Injector Flow Rate (Grams/Second)
Manifold Vacuum kPa {link: GM.MANVAC} Value
0 3.617188
5 3.640625
10 3.664063
15 3.687500
20 3.710938
25 3.726563
30 3.750000
35 3.773438
40 3.796875
45 3.812500
50 3.835938
55 3.859375
60 3.882813
65 3.898438
70 3.921875
75 3.945313
80 3.960938
