Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Missing calc.pids
  1. #21
    Jan 2005
    Quote Originally Posted by curtbriggs
    Paul,
    1, the PID list from the AutoVE tutorial.
    2. It just describes what the PID is, not what the problem is.
    Thanks, Curt
    Maybe the unsupported PID you are looking at is not a calculated PID? Which PID is it (are they) exactly?
    OK DESCRIPTION CAPTION UNITS SYSTEM CH PARAMETER
    - Absolute Throttle Position TP % - Throttle 1
    - Commanded Air Fuel Ratio AFR :1 - Fuel 2
    - Engine Coolant Temperature ECT °C,°F Imperial Temperature 1
    - Engine RPM RPM RPM - Conditions 2
    - Ignition Timing Advance for #1 Cylinder SPARKADV Degrees - Spark 1
    - Intake Air Temperature IAT °C,°F Imperial Temperature 1
    - Intake Manifold Absolute Pressure MAP kPa,inHg Imperial Air 1
    - Retard Due to Knock KR Degrees - Spark 1
    - Vehicle Speed Sensor VSS KMH,MPH Imperial Conditions 1
    Paul, the above are all selected but have the red X.
    The only two that are Calculated are OK, the two PLX PIDs. The analog voltage and the cyl/grams are also OK.
    I didn't have this problem with the pre-release 7.3, why now?
    I'll go over all your replys in this section and see if it makes sense.
    Thanks. Curt
    99C5, mn6, Vortec T trim, Snow meth injection, AFR 205s, ARP studs,Comp 224*112*+2*.580", YellaTerra RRs, PRC Ti's w/dbls, Supermaxx LTs, No Cats, Corsa Indys, LS6Intk, Hurst, Fikse Aro18"s. Pilot Sports 315/30,265/35, 04ZO6 Shocks Hotchkis bars, EBC YellowStuff pads, SS hoses, LM-1, EFILive, 2002 OS. RPS dual disc Clutch, DTE Strut Brace & output shaft.
  2. #22
    Have you changed the VIN in your PCM?
    Can you please generate an error report (Ctrl+G) and send it to me at paul@efilive.com. Thanks.
  1. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 05:39 AM
  2. _M/_DMA PIDs on E67 missing
    By scdyne in forum E37, E38 & E67 PFI ECM's
    Last Post: July 30th, 2008, 01:31 PM
  3. GMPP E67 missing pids??
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2008, 08:44 PM
  4. Missing PIDs
    By Ninety8C5 in forum FlashScan V2 BB Logging
    Last Post: March 24th, 2008, 06:07 PM
  5. CALC pids
    By purrvert in forum General
    Last Post: October 25th, 2005, 12:32 AM
