Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: Official Public Release - August 16,2010
  1. #21
    Quote Originally Posted by L31Sleeper View Post
    Paul would it be possible to make a Shift Point table showing all of the points on one chart?
    Make a table with user selectable parameters like 1>2 2>1 2>3 3>2 3>4 4>3 does that make sense ?
    I thought about this a little more today, that is exactly how we used to have the shift points, enough people complained they wanted to show just upshifts or just downshifts so we changed it.
    The answer as already noted is to make it user configurable, something Paul may implement in the version 8 tuner.
    Check this out from our revision log for the LS1 calibrations:
    v7.12 | 2004-Aug-01 | Split D0903 into two cals (upshift and downshift), new table is D0906.
    And since then that is the way we've done it.
  2. #22
    Nov 2007
    wow so there is really no pleasing EVERYONE. When I took the EFI Live class Justin said that the computer
    would get confused if the UP and Down shift graphs ever cross ? One table seems like a simple solution.
  3. #23
    Quote Originally Posted by 5.7ute View Post
    Not that I want to make any more work for myself. But the multiple address function in the .cax file would allow different shift parameters to be viewed & edited in the one table.
    What is the maximum number of addresses that can be used in the one table?
    1024
  4. #24
    Oct 2006
    Thanks Paul
    The Tremor at AIR
  5. #25
    Nov 2006
    I'm having to open the RTACS filter properties before RTACS will start.
    This is a little annoying.
    LC-1 WBO2
  6. #26
    Lifetime Member johnv's Avatar
    Jan 2005
    Just updaded to latest release,
    now i get "no roadrunner usb device found" when i attempt to connect RR.
    I guess i need to re enstall RR drivers ?
    anyone got a link on how to do this manually with Vista ?
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
  7. #27
    Quote Originally Posted by johnv View Post
    It may just be that you need to change the RR settings between Native USB and Virtual Com Port in the Tune Tool RR Properties window.
    To re-install the drivers, right click on MY Computer, select Properties. Find the Hardware Manager option and expand the USB Devices section. Find RR in the USB section, right click on it and select Update Drivers. Follow the steps on the screen and choose the option that allows you to select the drivers from a specific location. The drivers should be in \Program Files\EFILive\Drivers\RoadRunner\Win-2K-XP
  8. #28
    Jan 2005
    Thanks Paul,
    Just changed from virtual com port to native and all is good again.
    Back yard boost
  9. #29
    Quote Originally Posted by mr.prick View Post
    That is strange, I just tried a 512K LS1 Roadrunner and it worked without having to open the filters.
    Any more info on this?
  10. #30
    Jan 2006
    I still get the hapi error that never ends when I close V8. I have the latest updates installed. I have to end it through the control panel or reboot the pcm.
  1. August 12, 2010 Pre-release
    Last Post: September 29th, 2010, 07:12 AM
