I've got a customers car who had a ls3 installed into a ls1, The car is popping at idle hard to start and pulls a cam sensor code. After pulling the sensor i found the cam wheel is a 4x ls3 type not the normal single for the ls1. Is there anyway this problem can be fixed through the tune or does it need to be swapped over
Cheers
