Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Autocal Questions
    Lifetime Member macca_779's Avatar
    Jan 2007
    Default Autocal Questions
    Hey guys just a few q's on the new Autocal's as I'm organising a group buy on the LS1 fourms and want to confirm a few things as follows;
    • When a customer buys a set of Autocal's and subsequently has to use their V2 Serial # it's purely for purchase validation to ensure your a current EFI LIVE customer right. ie I won't be locking the devices so that only I can supply them tunes to use on their Autocal's
    • As far as scanning goes. Are there any limitations outside of what a V2 can do. ie The scanning software can be fully utilised and BBL data can be real time viewed on the Autocal LCD (obviously less info at anyone time over the V2 due to the size of the screen)
    • Can we full Flash OS' yet as I have guys that will be going from stock to a COS and require the capability
    Cheers
    Ryan
    Oct 2004
    The AutoCal device does become linked to the FlashScan V2 device. Only tunes created by the person with the FlashScan V2 serial number can provide tunes for AutoCal devices locked to their V2 SN.
    The AutoCal device has similar BBL capability with the exception (as you mention already) of physical display size. Also, there is no A/D or serial input so WBO2 controllers and other external devices cannot be logged.
    Pretty sure full flash is not implemented at this stage (Paul can correct me if I'm wrong). It of course will be.
    Andrew
    EFILive Crew
    Cant answer #1 for you, but I would like to get clarification as well. Im assuming its just to make sure the purchaser has a V2 so someone doesnt order an AutoCal unit thinking they can flash their own tunes in without a V2.
    Not as far as I can tell, scanning, logging, DTC clearing, etc can be done with an AC. Havent checked to see if realtime data is on the screen, need to play with mine a little more.
    No, full flashing is not implemented yet for any controllers. Cal flashing is mostly done, know the A50 Alli TCMs cant be flashed yet (but dont think they can in V7 either).
    EDIT:
    Andrew beat me by seconds!
    Jan 2007
    Ok now that I know Autocal's can only use files supplied by the linked V2. Can you add further V2's to the Autocal so that your not limited to the one tuner and if so how many extra V2's can be linked and how is this process acompolished, remotly via serial number input or physically by a requirement to have the Autocal on hand to sync it to the V2. For example can you and your tuner both have V2's so tunes can be supplied by both of you, but can a further tuner be attached to the Autocal so he too can supply tunes.
    This is important for the group buy I'm organising as guys will not necessarily be supplied tunes from me.
    Also will the following example run true. As I have a guy who's tuner uses HPT but is interested in Autocal to have multiple tunes available to him eg valet/normal.
    If he buys an Autocal off me, it will obviously be linked to my V2. But can he pull his tune from his current car and save it. Then have his tuner flash in an alternate tune and pull it also. By my understanding he is only pulling tunes already in his controller so is this possible.
    One last question. Is Autocal free to read controllers at will without licensing the same as we can do with a V2?
    Cheers
    Ryan.
    Oct 2004
    Just to clarify the purpose of the AutoCal device... The AutoCal device is purchased by a Tuner (professional tuner, workshop or parts supplier) and used as a mechanism to provide tuning services to their Customer. While the Customer receives an AutoCal device physically, it is solely to use the tunes provided by the Tuner.
    The linking of a single AutoCal to multiple FlashScan V2 is possible, however the license number of the V2 has to be the same (so they would be owned by effectively one tuner/shop). It is not possible to link the AutoCal to FlashScan devices from competing Tuners for instance.
    Think of it sort of like a cable TV set top box from CompanyA. The device you might get from CompanyA could very well be exactly the same physical hardware as a box from CompanyB. While the hardware is the same the box from CompanyA is of no use with CompanyB as the box is ultimately a means for CompanyA to provide you with a service (in this case pay TV). Hopefully that makes sense, it was the best analogy I could think of...
    The calibration files the are save to the AutoCal have the expected device serial/license number embedded. It is not as simple as just copying a .CTD file to AutoCal and then being able to flash it.
    For what you are trying to do (a group buy) the end user would need to either own a FlashScan V2 (in which case why get an AutoCal?) or would need to know someone with a FlashScan V2 (you or another friend etc.). I can see why you'd want to do a group buy, but you really need to consider that the AutoCal is not simply supposed to be a cheap FlashScan V2, it provides a specific purpose.
    Reading calibrations is still not a licensed function. While it might be possible to read tunes, the purpose is essentially to provide your Tuner with your stock or current tune to be modified and sent back for local flashing.
    Andrew
    EFILive Crew
    Nov 2006
    I thought the AutoCal was going to be lesser version of the V2.
    Kind like pptuners "standard" version.
    LC-1 WBO2
    Apr 2008
    correct me if I am wrong,
    V2 is master device and autocal is slave liked to it. I will be the only one who can supply tunes to my slave devices??
    is the file that I am going to create then send will be encrypted or he can look at my tune? I am dealer and tuner of SCT, nobody can see ur file unless he is using another way of reading the file like using a device that read binary files.....etc
    Regards,
    Odd Boy
    Quote Originally Posted by mr.prick View Post
    No, that was never the intention of AutoCal. It was to provide an easy way for tuners to remotely deploy tunes without having customers physically send PCM/ECM/TCMs to them.
    Quote Originally Posted by odd boy View Post
    Yes, a V2 serial number is the "master" and can have many AutoCal "slaves". But an AutoCal "slave" cannot have more than 1 V2 "master" serial number.
    *.ctd files are not encrypted at this time, not sure what EFILive's plans are for this. So yes, your tune files can be opened and viewed by anyone that has access to the file, however they cannot re-save the file. If they do, the file will lose its V2 serial number and then the AC will be unable to flash the modified *.ctd. This means that only you the tuner can save files with your specific V2 serial number and email them to the end user to flash.
    Oct 2004
    Yes, V2 is a "master" and can have many AutoCal "slaves". But an AutoCal "slave" cannot have more than 1 V2 "master".
    AutoCal can actaulyl be linked to many FlashScans, but the FlashScan license number needs to be the same, so typically that might be a workshop with more than one V2 device.
    The .CTD format has always been encrypted. In the latest V7 release made just couple of days back (7.5.6 Build 130) there is a new 'Permissions' tab in the calibration that allows you to flag the .CTD file so that it cannot be viewed or modified
    Andrew
    EFILive Crew
    Quote Originally Posted by Tordne View Post
    Just clarified my last post, meant to say a V2 serial number is the "master" and the ACs are "slaves".
    Shows you how much time Ive had to look at the newest software, I downloaded it before I went to pull an 08 Escalade tune but didnt actually look around in it. I know V8 has had that feature in there for a while... Didnt know if V7 was going to get that option or not.
  1. Autocal?
    By macca_779 in forum Lounge
    Last Post: August 18th, 2010, 09:50 AM
  2. Autocal
    By Frost in forum Lounge
    Last Post: May 10th, 2010, 01:27 PM
  3. Autocal
    By Alvin in forum Lounge
    Last Post: August 1st, 2007, 01:55 PM
