Results 1 to 10 of 12
Thread: OL question????
    Aug 2008
    Default OL question????
    Is it possible to run 2002-2005 2.2ltr Ecotec engine's in OL-mode? I just built a stand-alone harness and I'm trying to figure out if it's even possible to run these motor's without an O2 sensor...I wonder If I unplug O2 sensor if it will just default to OL...
    Anyone?
    FLASHSCAN V2 & AUTOCAL
    Aug 2008
    Here's a tune file I'm working with...
    Aug 2008
    Unhappy
    No one?
    Aug 2008
    Still trying to find out if OPEN LOOP is possible for Turbocharging a 2.2ltr ECOTEC...
    I think my P10 defaulted to open loop when I unplugged the O2 sensor, maybe try unplugging it and see what the fuel system mode is in the Scan tool.
    Aug 2008
    Thats my last option...
    May 2010
    Thats your only option. Im running mine in open loop no problems . Just disconnect the o2. Watch it with a wideband.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    May 2010
    Also some guys are swapping in a 97-02 L4 big pcm from a s10 or cavalier, and running there ecotec with it.
    May 2010
    To bad you dont have the other tuning software. You could flash in a factory LD9 supercharger file, from a cavalier. It would be great for what your running, being a standalone.
    Aug 2008
    Quote Originally Posted by slows10 View Post
    Really??? That sounds better than this P11
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 10:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 02:22 PM
