Originally Posted by Wichita Dyno Even if I select wideband pid i cant seem to find my ben pids. In the scantool, on the PIDs tab, click twice on the column heading "Parameter" (i.e. on the word "Parameter")... now look down this column until you see your pids. Which wideband/pids were they...?
Originally Posted by mr.prick Were these PIDs made by you or EFILive? Is it possible the calc_pids.txt was written over after a new install/update? Good point... were the pids sourced from calc_pids.txt...?
I cant explain what happened. I hooked up to a different vehicle, same year and model and the pids are back as supported pids.
I forgot to say this: uncheck Supported on the PIDs tab. Oh, you see them now, cool
Forum Rules
