Results 1 to 10 of 14
Thread: Lost all wideband analog and serial pids
    Aug 2007
    Default Lost all wideband analog and serial pids
    After latest update ive lost all wideband and calc. pids I use for auto ve tuning. Can someone help me through this? Thanks in advance.
    Chris
    Hi Chris,
    Use the Scan&Tune (S&T) software (comes with V8 install), see attached... click Program to program it to your V2.
Name:	S&T - Device Settings - BBL.png
ID:	8846   Click image for larger version.
Name:	S&T - Device Setings - Serial IO.png
    Aug 2007
    Thanks so much for the help. Awsome software and support!
    Aug 2007
    I did as shown above and also updated firmware and boot block. Still when I connect to vehicle all wideband, analog and serial as well as ben's dont show up as supported pids for this 00 transam. Im guessing its a problem with calc pids? V2 is set to proper lc1 serial wideband. Any help would be appreciated.
    Oct 2004
    Are you Black Box Logging or pass-thru (using the Scan Tool)?
    Andrew
    EFILive Crew
    Aug 2007
    Im using the scan tool with laptop on dyno to tune and data log.
    Nov 2006
    It's okay if they are not valid.
    Select them anyways, once you start logging they will become valid and data will be visible.
    This happens sometimes with passthru.
    LC-1 WBO2
    Aug 2007
    Even if I select wideband pid i cant seem to find my ben pids.
    Oct 2004
    There were a couple of Serial PIDs actually shown in the WBO2-Analogue section incorrectly that was corrected in the last update. So, perhaps they have just moved?
    Andrew
    EFILive Crew
    Nov 2006
    Were these PIDs made by you or EFILive?
    Is it possible the calc_pids.txt was written over after a new install/update?
    LC-1 WBO2
  1. Lost PIDS / Calibrations
    By Big D in forum General (Diesel)
    Last Post: March 13th, 2010, 09:05 AM
  2. log serial wideband
    By b18cls1 in forum Black Box Logging
    Last Post: February 12th, 2010, 04:46 AM
  3. BEN is only for analog, right? How do I log BEN with serial logging?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 12th, 2009, 06:08 PM
  4. Lost serial input.........
    By Redline Motorsports in forum General
    Last Post: June 1st, 2009, 02:34 AM
  5. serial wideband
    By articSS in forum Black Box Logging
    Last Post: December 19th, 2008, 07:04 AM
