Results 1 to 2 of 2
Thread: Latest 7.3
    Jan 2005
    Default Latest 7.3
    You can't copy and paste or print the readme info.
    99C5, mn6, Vortec T trim, Snow meth injection, AFR 205s, ARP studs,Comp 224*112*+2*.580", YellaTerra RRs, PRC Ti's w/dbls, Supermaxx LTs, No Cats, Corsa Indys, LS6Intk, Hurst, Fikse Aro18"s. Pilot Sports 315/30,265/35, 04ZO6 Shocks Hotchkis bars, EBC YellowStuff pads, SS hoses, LM-1, EFILive, 2002 OS. RPS dual disc Clutch, DTE Strut Brace & output shaft.
    Default Re: Latest 7.3
    Quote Originally Posted by curtbriggs
    Click in the readme window and press Ctrl+A to select all text. Then press Ctrl+C to copy it to the Windows clipboard.
    Or
    You can right click on the *.exe that you downloaded and select "Extract Files...".
    If you extract the files to a folder called: EFILiveV730_314_456_329, then the readme file will be here:
    EFILiveV730_314_456_329\EFILive\program files\EFILive\V7\Readme.rtf
    Or
    After installation, the Readme.txt file is in:
    \Program files\EFILive\V7\Readme.rtf
  1. Latest update
    Last Post: June 28th, 2008, 03:55 AM
  2. latest update...where to put M81 bin?
    By serpa4 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 1st, 2007, 10:31 AM
  3. Latest Update
    Last Post: October 4th, 2006, 09:55 AM
