You can't copy and paste or print the readme info.
99C5, mn6, Vortec T trim, Snow meth injection, AFR 205s, ARP studs,Comp 224*112*+2*.580", YellaTerra RRs, PRC Ti's w/dbls, Supermaxx LTs, No Cats, Corsa Indys, LS6Intk, Hurst, Fikse Aro18"s. Pilot Sports 315/30,265/35, 04ZO6 Shocks Hotchkis bars, EBC YellowStuff pads, SS hoses, LM-1, EFILive, 2002 OS. RPS dual disc Clutch, DTE Strut Brace & output shaft.
Click in the readme window and press Ctrl+A to select all text. Then press Ctrl+C to copy it to the Windows clipboard.Originally Posted by curtbriggs
Or
You can right click on the *.exe that you downloaded and select "Extract Files...".
If you extract the files to a folder called: EFILiveV730_314_456_329, then the readme file will be here:
EFILiveV730_314_456_329\EFILive\program files\EFILive\V7\Readme.rtf
Or
After installation, the Readme.txt file is in:
\Program files\EFILive\V7\Readme.rtf
