Results 1 to 5 of 5
Thread: Share Stream
    Nov 2007
    Default Share Stream
    Paul recently explained that the V2 Serial number can be separate from the
    License number if the customer so wishes. i.e. one shop with multiple V2s
    So the question is a stream attached to the serial or license number ?
    Can one stream be purchased for the shop and used on all devices in the
    shop ?
    Jul 2004
    I that's a no, every V2 needs it's own stream. The license number being the same just means that matching V2s can unlock each others built in lock codes, nothing else.
    Ira
    Nov 2007
    Quote Originally Posted by Ira View Post
    Ira
    What is a built in lock code ??
    Feb 2006
    I think it is used when you allow the V2 to create its own lock code for locking PCM's. You would need to you that specific V2 to unlock the PCM that was locked with it.
    Al
    Nov 2007
    OOOOooooo......k that makes a lot of sense so if your V2 gets broken EFI Live can send you a
    new one with your old License number on it so you are not Locked out of your own PCMs
    Now they are using it on AutoCals which are by nature locked.
  1. Share your Filters!
    By mr.prick in forum Tips and tricks
    Last Post: April 29th, 2009, 01:40 AM
  2. 2006 Trailblazer SS V2 tune anyone want to share?
    By rx7636 in forum Gen IV V8 Specific
    Last Post: March 3rd, 2009, 12:28 PM
  3. Anyone willing to share LL8 PCM Pinout?
    By Automotive Innovations in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: January 23rd, 2008, 09:16 PM
  4. Thought I'd share...
    By SSpdDmon in forum Lounge
    Last Post: August 7th, 2007, 09:26 AM
  5. Wanted to share some part numbers
    By 98SS2836 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2006, 08:03 PM
