Results 1 to 2 of 2
Thread: hi! everyone
    Aug 2010
    Default hi! everyone
    Hi, friends! I just receive my aldl cable and software http://www.aldlcable.com/sc/details.asp?item=aldlobd1u so, I could`nt receive any data from my dear daewoo matiz year 2000, it seem like no connection with ecu, I just send them a mail asking for some solution and well I hope the find it, but I would like to know if someone of you has some idea about the problem, any help will be apreciate...regards
    connecting efilive this is show me:
    32.21.579 initialising...
    32.21.582 Opening com3 8228,8,N,1
    32.21.866 Ready
    32.27.038: Check vehicle interface...
    32.27.049: Waiting for Aldl bus silence of at least 50ms...
    32.27.100: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    32.27.119: Max232 interface detected OK
    32.27.127: Scanning for heartbeat and chatter frames...
    32.27.127: Waiting for Aldl bus silence of at least 50ms...
    32.27.378: Com timeout: Expecting frame header byte
    32.27.410: No chatter found
    any ideas?
    The "no chatter detected" may be simply because the ECM does not send out any chatter data.
    Do you have the Daewoo.xml data stream definition file loaded into the EFILive V4 software?
    Try selecting the "Get engine data and DTCs (DATADTC)" macro and then clicking on the green start ALDL button in the tool bar.
