Results 1 to 3 of 3
Thread: Logging Throttle cracker table and Logging to diagnose a missfire
    Dec 2009
    Exclamation Logging Throttle cracker table and Logging to diagnose a missfire
    Throttle Cracker - Is there a custom PID and MAP that has been made or that can be made to log what is the desired airflow for the cracker table? (just like the RAFPN AND RAFIG PIDS)?
    Missfire logging -
    What Pids do i love to diagnose a missfire. Im getting a misfire while driving in the low to mid rpm range. Car runs great power wise. Let me know what I should do thanks.
    Misfire:
    - first, do a CASE relearn.
    - then, log the pids MFCYL1,2,3,4,5,6,7,8 to see which cylinders the PCM thinks are misfiring.
    - are you sure compression is good on all cylinders....?
    - are you sure there are no internal coolant leaks...?
    - are you sure ignition components are good/firing...?
    - are you sure injectors are good/firing...?
    Oct 2006
    Quote Originally Posted by z28ls1818 View Post
    No. Cracker & follower are more a drivability based table and do not utilise trims. (which is what rafig & rafpn use to dial in desired airflow)
    Too much TC & you can have that annoying "cam surge" at lower RPM/ throttle positions and/or a cruise control effect when lifting the throttle. Too little & you will have excessive engine braking when lifting the throttle.(Some like this)
    TF airflow I use to help smooth out small throttle changes & also prevent the throttle from effectively "snapping shut" on a full lift of the throttle, which can cause all sorts of stalling issues.
    The Tremor at AIR
  1. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
  2. logging throttle cracker and follower?
    Last Post: January 2nd, 2010, 03:56 PM
  3. throttle cracker
    By Boost in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2007, 09:53 PM
  4. Throttle Cracker P/N
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 27th, 2007, 02:32 PM
  5. Throttle Cracker question
    By DaddySS in forum Gen III V8 Specific
    Last Post: September 2nd, 2007, 05:10 AM
