Results 1 to 7 of 7
Thread: What are differences in WB AFR readings from before cat, after cat and at tail pipe?
    Lifetime Member Chalky's Avatar
    Sep 2003
    Question What are differences in WB AFR readings from before cat, after cat and at tail pipe?
    Has anyone had a chance to compare afr readings a on the same tune but sampling WB AFR at different points in exhaust system?
    I know there is not absolute answer but there must be some consensus on what impact taking readings before, after cats and using a tail pipe sniffer will have on wb afr readings.
    I am sure the best readings are at collectors and before the cats but in the real world, most people do not have bungs before the cats and most tuners are tuning using tail pipe sniffers.
    2015 Z06 A8
    Junior Member chpspecial's Avatar
    Dec 2005
    Quote Originally Posted by Chalky View Post
    On my 2004 silverado SS with an STS kit, the readings where less than .01 AFR. the pre cat WBO2 sensor was an innovate LC1, the tailpipe WBO2 sensor was the innovate LM1. this was with cats still on the truck.
    Quote Originally Posted by chpspecial View Post
    Really? Hmmm good information. Was this at WOT or cruise?
    Dec 2005
    it was both, I wanted to verify the readings off the lc1 by intalling the lm1. I too was surprised to see the little varience. however, this would only apply to vehicles that do not have an airpump at the cats. luckly GM doesnt use air pumps on our trucks.
    Jul 2003
    I never noticed much if at all a difference, before or after the cats. IF you can put them before, then by all means do so... If you cannot put them before, doesn't matter. Point is. the shorter the distance the more accurate it will be to fix the MAF table.
    Lifetime Member johnv's Avatar
    Jan 2005
    I haven't seen alot of difference, you can see erratic readings at idle from the tailpipe if you don't have a good probe for the sensor.
    And as said by Highlander the closer the sensor is to the engine the less lag you get and the more accurate the reading will be for the VE table cell that your logging.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    Hmm, well I stand corrected for preaching about only going pre-cat for WBO2s. I do like mine being nice and close though, throttle changes are very close to reported WB readings.
  1. Cat protection
    By Ram Air IV in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2010, 05:12 PM
  2. are the pre cat and post cat 02 sensors the same?
    By smslyguy in forum Gen III V8 Specific
    Last Post: September 15th, 2009, 01:20 PM
  3. Cat removal
    By pjaneiro in forum General (Petrol, Gas, Ethanol)
    Last Post: August 16th, 2008, 08:58 AM
  4. Before and after cat.....
    By chrleb2 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2008, 05:06 AM
  5. Cat delete
    By Automotive Innovations in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 27th, 2007, 11:52 PM
