Results 1 to 7 of 7
Thread: Data Logging Error
    Aug 2010
    Default Data Logging Error
    $0281.
    What does this mean? Just started using the autocal wanting to log some data on my Tahoe. Thanks!
    Aug 2010
    I believe the 281 code is the device could not be found?
    Well I am able to read DTC's (there are none) and read off the current tune on my truck.
    Ryanbabz71, welcome to the forum...
    $0281 might be "No data received".
    Which FlashScan/AutoCal firmware version...?
    The error codes are described in the document that is installed at:
    Start->All Programs->EFILive->V8->Documents->EFILive Error Messages.pdf
    $281 is "No Data Received".
    Assuming all connections are ok and ignition is on and the OBDII connector has power (check cig lighter fuse), then that error can be caused if you don't have a transmission controller (i.e. a stick shift) and you have a trans controller defined in your selected PID list.
    Aug 2010
    How do I go about changing this?
    In the PID Selections Scan Settings (F3) I have the following for the transmission:
    TFT, TIS, TOS, TCCSLIP, Gear
    Software:
    Firmware: 2.06.40
    Bootblock: 2.06.03
    Like I said before I can pull the current tune off the truck and check DTCs so something is working.
    Ryan,
    What year is the Tahoe...?
    Does it have a ECM/TCM pair or just a PCM...?
    In S&T software, which ECM and TCM do you have selected...?
    Try removing the TCM.
    Aug 2010
    Truck that is tuned is a 2010 with 6.2 6 speed
    The Tahoe is an 08 with 5.3 4 speed
    I think I may know what the issue is. I do not have a reference file (E38?) on the autocal. Is this true the general file needs to be moved over to the tune file in explorer?
  1. Error $0281....no data received
    By y2k2z28 in forum FlashScan V2 BB Logging
    Last Post: October 23rd, 2016, 11:08 AM
  2. V1 Data logging
    By Harrismarine in forum General (Petrol, Gas, Ethanol)
    Last Post: December 2nd, 2007, 07:01 PM
  3. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  4. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
