Results 1 to 4 of 4
Thread: LMM: VATS and new ECM
    Jan 2006
    Default LMM: VATS and new ECM
    Why doesn't the new ECM require the VATS cycle upon installation? It started right up. Here are the programmed values.
    LABELS Anti Theft
    Parameters Value
    {G0301} Anti Theft Enable
    {G0302} Relearn Timer 600.000000 Seconds
    {G0304} Relearn Count 1 3.000000 Counts
    {G0308} Anti-Theft System Type PK3
    Custom Tuning Services
    Because there is no existing VATS codes already in the ECM, that gives it a free pass to learn.
    Jan 2006
    ok, I get it now. Thank you.
    Jan 2006
    Opening this back up for discussion. I change the timer to 10 seconds, install the tune, but the security light does not go out in 10 seconds (I believe it goes out in 10 minutes). Had this happen on 2 vehicles, 2 different ecms.
    Any ideas?
  1. 2010 LMM ECM tuning?
    By cumminsDK in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 4th, 2010, 06:26 PM
  2. LMM ECM replacement questions
    By rcr1978 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 22nd, 2009, 12:18 PM
  3. LBZ/LMM VATs
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 22nd, 2007, 09:56 PM
