Results 1 to 10 of 19
Thread: Full Flash option greyed out.
    Junior Member carl0s's Avatar
    Oct 2009
    Default Full Flash option greyed out.
    I want to try loading the 2006 operating system onto my 2005 GTO E40 PCM, because I read somewhere that full CAN stuff wasn't implemented until 2006.
    I downloaded a tune file from holdencrazy.com but the option to Full Flash is greyed out.
    Am I missing something ?
    cheers,
    Carl
    Oct 2009
    Ignore me. It's working :-)
    The cable wasn't detected upon start up, even though it was working with the cable in other ways.
    I had to restart EFILive.
    Hope I don't break my ECM !
    cheers,
    Carl
    Oct 2009
    Hmm. The bootblock numbers are not compatible :-( Should I override that check ?
    Oct 2009
    Meh. Won't let me do it because boot blocks are incompatible :-(
    Carl,
    Do you have FlashScan V2...?
    Which firmware version is in it...?
    Oct 2009
    Hi Joe. Yes it's a V2 and I have the latest firmware etc. from about 2 or 3 weeks ago.
    The full flash option works now, it's just that I'm not allowed to use an OS from a 2006 E40 ECM on my 2005 E40 ECM :-(
    I hope the thing I read about CAN support was wrong ..
    The check is in there to stop you killing the ECM.
    GM made a change on the E40 that makes the later operating systems incompatible with the early ECM's. I can tell you that there is been numerous E40's bricked beyond repair by GM's SPS for this very problem.
    If you post up what the existing Operating System is in your E40 and what the one is you want to flash in I'll double check that they aren't compatible for you.
    Nov 2007
    What a nice guy...........LOL
    Oct 2009
    Thanks Ross.
    The current OS is 12596734
    I was trying to flash any 2006 OS that I can find, which is:
    12603159 or 12604792.
    Do you know whether there is in fact any difference in the High-Speed CAN / GMLAN protocol between the 2005 and 2006 E40s ?
    As it turns out, someone I know locally-ish has a 2006 LS2 with an E40, so I may get to have a look first hand.
    So far, I am hoping that once I start broadcasting the last 8 digits of my VIN, every second, on the CAN bus, that the ECM will think "hey.. PIM! There you are! Let's talk!", and things will start to look how I expect them to.
    Right now, the CAN frames coming out of my ECM look nothing like the GMLAN specs (GMW8762) say they should, but then I have no PIM or BCM so there's nothing for the ECM to be talking GMLAN with anyway.
    I have had a look at capture from a 2006 Impala SS and everything looks perfect on that vehicle! All as per the specs.
    The GMW8762 specs say:
    This document defines a standard electrical
    interface between Platform and Powertrain
    systems and components on all GM (General
    Motors) cars and light duty trucks equipped with
    internal combustion engines. It shall apply to all
    Platform Electrical or Vehicle Majors in Model Year
    2005 and beyond.
    I am worried that the 2005 GTO somehow wasn't included in that, and that only the 126xx OS fits the spec. I'll find out soon enough I suppose.
    Dec 2007
    Quote Originally Posted by carl0s View Post
    Thanks Ross.
    FYI - and would defer to Ross on this for a definitive answer but 12603159 is usually the danger OS to flash into earlier E40s' (svc# 12597883) and vice versa that causes brickification. 12604792 is more likely to be compatible - but even if it doesnt brick it - in a regular production car it may cause some issues. With any luck GM has not changed the message set but with different emissions regs coming in for 06 maybe this might drive the changes. C6 LS2's had E38's for 06 whereas GTO LS2's had E40's. (?)
    Do you have a CAN problem. Would be interesting to know what you are scanning the CAN frames with? And where can the GM specs be obtained? Is GMW8762 available from GM?
  1. Pre Full Flash to Full Flash Tune Question
    Last Post: January 13th, 2010, 12:43 PM
  2. Full Flash
    By L31Sleeper in forum Vortec V6/V8 Specific
    Last Post: November 26th, 2009, 10:25 PM
  3. trying to full flash tcm
    By j-man345 in forum Allison 5 & 6 Speed
    Last Post: August 12th, 2009, 03:03 PM
  4. HELP cant full flash
    By Madspeed in forum Duramax LLY
    Last Post: April 23rd, 2007, 07:05 PM
  5. Full flash
    Last Post: June 11th, 2006, 06:28 PM
