Exactly what I was looking at. They seem to work OK for a while, but then stop switching. At this point, they indicate they are stuck in a "lean" state (very low OP voltage), but the LTFT's remain around -10% and keep pulling fuel. So either the LTFT learn rate is very slow, or the PCM has dropped into OL mode and turned off LTFT learning. If it was just a vacuum leak, the trims would keep things in check and the LTFT's would be positive to compensate for air flow not measured by the MAF. It should also be worse at low MAP readings, where a leak would have more of an effect. Maybe it's full PCM reset time and clear all trims, start from scratch?
Simon.
