Results 1 to 8 of 8
Thread: Biodiesel & Regen.
    Aug 2010
    Default Biodiesel & Regen.
    Hello All,
    I'm brandnew to this forum and already have an iffy question.
    I was reffered to you by one of our fellow biodiesel infopop forum members because I have a 2010 Chevy with the 6.6 Duramax which utilizes a DPF to burn off excess soot in a socalled regen cycle. Now, I'm a biodiesel advocate and would like to run b100 in this truck but have been informed that the computer get's confused with the bio/DPF equation.
    Does any of your product allow the ECM to be recalibrated so that the regen cycle just does not happen? (especially since b100 doesn't produce any soot).
    Thanks in advance,
    Thomas
    Jan 2008
    I haven't seen a 2010 tune but i know that you can remove and tune out the DPF and the regen cycle on the '08's I would imagine that the same OS is being used for the 2010's as well
    Aug 2010
    Thanks for the reply
    Can the regen cycle be tuned out without a delete kit or will I definitely need a DPF delete pipe?
    Thomas
    Junior Member MadMaxx61's Avatar
    Jan 2008
    You can just turn it off but over some time it will still fill with soot even with B100. So the delete is the way to go plus you will gain MPG and some power as it will flow a lot more also ditch the DOC for the best MPG. Now people will say that is bad for the environment but think if you burn less fuel you will make less emissions over all.
    2008 2500HD 4X4 LTZ Z71 6.6L LMM
    Mods: EFILive, MBRP 4" DPF Delete, BD Manifold, SD Manifold, SD Center Link, SD Sleeves, S&B Intake, FS-2500, PPE Trans Pan, Bushwacker fender flares, PPE Oil Centrifuge, And other non-go-fast things.
    Things still need to put in: PCV Re-Route,Air Dog AD-200.
    Jan 2008
    There is a sticky at the top of this sub forum http://forum.efilive.com/showthread....moval-write-up
    Yeah you would need the delete pipe also. or the DPF would get plugged up.
    Aug 2010
    What would the efilive system be that I need and do they have the pipe too?
    Thomas
    Sep 2007
    There are vendors that will sell you the efilive program or an ecm programmed with efilive along with the dpf delete kit.
    Aug 2010
    Thank you guys. I'll research.
    Thomas
  1. lmm dvt service regen
    By cumminsDK in forum Diesel
    Last Post: September 1st, 2010, 08:27 AM
  2. DPF Regen Effectiveness
    Last Post: May 19th, 2010, 07:08 AM
  3. Really need LMM>V2 Regen help asap!
    By Sleepertrk in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 16th, 2008, 01:12 PM
  4. how to tell if regen is on
    By ods dan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2008, 01:51 AM
  5. manual regen on LMM's
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 15th, 2007, 05:01 AM
