Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: logging for TCM
  1. #11
    Jan 2008
    You can make a calc PID based on TOS, gear ratio, tire size. should be pretty simple...
    If you are using BBL, you can log both the TCM and ECM at the same time eliminating that problem. Just a suggestion. I know you are having a hard time coming over the dark side.
  2. #12
    Jan 2006
    Looks like I just found a good reason to make the move. Since autocal is based on the same interface, I can't put it off any longer.
    The calc pid occured to me. I am just becoming averse to work.
    Custom Tuning Services
  1. Logging Throttle cracker table and Logging to diagnose a missfire
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: August 26th, 2010, 06:01 PM
  2. Scanning 06+ TCM's
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 30th, 2007, 09:43 AM
  3. Can't Read TCM
    By ARK 99coupe in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2007, 02:32 PM
  4. No TCM = Derated ?
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 7th, 2007, 12:00 PM
  5. Eliminate TCM
    Last Post: March 29th, 2007, 01:27 AM
