Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: BBL PIDs V2
    Feb 2004
    Default BBL PIDs V2
    I searched and found everything but what I needed. Is there a quick tutorial for loading selected PIDs into V2? I am not sure I did it correctly.
    Thanks!
    Oct 2004
    Check out this (sticky thread) which should hopefully help you out: http://forum.efilive.com/showthread....-V2-for-BBL...
    Andrew
    EFILive Crew
    Feb 2004
    Thank you. I either missed this in the search results, or it didn't come up. I appreciate the assist!
    Feb 2004
    OK, that much I have done. However, is there a way to select certain PIDs from all that are available for the LS1, or are you limited to just those that are default in V2 when you select the LS1? I have my custom PID list in Scan Tool. Is there a way to copy or import this PID list into V2? Even when my PC is connected to V2, my "Program Selected PIDs into Flashscan" in Scan Tool is grayed out. I am obviously doing something wrong.
    Make sure V7/V8 software is updated to latest, and that V2 firmware is latest.
    First, in EFILive Explorer (EE), goto Config Data tab, and format the Config space (click the Format button), exit EE when done.
    Then, in Scan&Tune (S&T), goto Black Box Settings, goto Scan Settings tab...
    and see attached for creating pidlists and populating them with pids for BBL:
    [ if you have manual trans, then do not select a second controller when creating a pidlist ]
Name:	S&T - Black Box Settings.png
ID:	8933   Click image for larger version.
Name:	pidlist properties.png
ID:	8934   Click image for larger version.
Name:	pidlist properties popup.png
ID:	8935   Click image for larger version.
Name:	S&T - Black Box Settings - Scan Settings.png
    To change a pid's custom properties (alternate units, alarm):
Name:	pid properties.png
ID:	8944   Click image for larger version.
Name:	pid properties popup - alarm.png
    BBF settings (which engine/trans controller):
Name:	S&T - Black Box Settings - Tune Settings.png
    Device settings (wideband serial parameters):
Name:	S&T - Device Settings - BBL.png
ID:	8947   Click image for larger version.
Name:	S&T - Device Setings - Serial IO.png
    Before you can BBL or BBF(BBR/BBW), you must format the Data Space:
    To format the internal Data File system:
    on the V2 keypad press Ctrl+Backspace, change File sys to Internal and press OK,
    then go F4 Options -> F2 File System -> F3 Format File Sys.
    To format the SD Card File system:
    on the V2 keypad press Ctrl+Backspace, change File sys to SD Card and press OK,
    Allow the format to finish.
    Quote Originally Posted by mnotx View Post
    Note that in the V7.5 scantool software, that is for FlashScan V1.
  1. Imperial pids for BBL?
    By thunderstruck507 in forum Black Box Logging
    Last Post: February 9th, 2010, 04:04 PM
  2. BBL Pids???'s
    By GAMEOVER in forum Black Box Logging
    Last Post: March 16th, 2009, 10:37 AM
  3. Bbl Pids?
    By Beer99C5 in forum FlashScan V2 BB Logging
    Last Post: July 31st, 2008, 07:57 AM
  4. BBL PIDs
    By mr.prick in forum FlashScan V2 BB Logging
    Last Post: July 4th, 2008, 04:26 PM
