Results 1 to 2 of 2
Thread: Check Sum
    May 2009
    Question Check Sum
    Can someone explain the full calculation and control parameters of CHECKSUM? Does the ECM or TCM perform the test? Is same VIN and/or model year OS essential between ECM/TCM? Thanks
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
    The checksum is something the ECM (or TCM) does on itself when the key is turned on. Depending on the controller type depends on the complexity of it. In a nutshell it adds up a range of numbers and those numbers must equal a known value. If it doesn't then the controller assumes the flash chip has gone bad and the result will usually be limp mode or something along those lines. When you make a change to the tune with EFILive the software creates the correct 'known value' checksum.
  1. check out my VE
    By nchristian in forum Gen III V8 Specific
    Last Post: June 17th, 2009, 04:01 PM
  2. Check this out
    By mr.prick in forum Lounge
    Last Post: January 26th, 2009, 06:31 AM
  3. Check this out! help!!
    By 05duramonster in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 4th, 2009, 12:39 PM
  4. how to check how much timing?
    By turboolds in forum Gen III V8 Specific
    Last Post: September 12th, 2008, 10:23 AM
  5. Please check my Tune
    By DocZ28 in forum Gen III V8 Specific
    Last Post: December 15th, 2007, 10:34 AM
Tags for this Thread
