Results 1 to 9 of 9
Thread: E-force help
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Red face E-force help
    We have the kit installed but we can't get it to run. The handheld unit appears to be useless Does anyone have an efilive format tune for a 2007 ls2 e38 ECM The super charger kit is installed but the car will not run. Does anyone have any suggestions? We tried to load a 2 bar map and the 52 lb injectors but the car refuses to start. I could sure use a functional tune for my car to get it running. What's the use in having a super charger if I
    can't drive the car?
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Apr 2004
    If you have a file please email to eboggs_jkvl@ls2.com
    this one's should help you out
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Apr 2004
    Quote Originally Posted by gmperformancecentre View Post
    Thanks. Are those stock tunes? We have the stock tune from the car. We need one for the supercharger with a 2 bar MAP and 52 lb injectors. We tried to load the 2 tables to get it running but something is still wrong. The car refuses to run.
    Elmer
    yes they are stock tunes.
    have a look at the 2009 zr1 ls3 supercharged stock tune i have uploaded and that might give you some help
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Apr 2004
    We'll hold that one for reference! Thanks. If we can get it running, then we can tune it.
    Apr 2004
    I've been playing with my stock tune and I:
    can set it for 2-bar
    can set the injectors
    CANNOT turn on Supercharger nor do I see all of the tables that the LS9 has.
    Without being able to "set" the SC setting to "yes" gives me a question on using the stock tune and append it. Do all of those tables need to be added? How can the SC be set to yes? It refuses to allow that to go to anything but "no".
    Elmer
    From every tune Ive seen, the s/c is either disabled (everything) or enabled (LS9/LSA) by GM, EFILive has the options greyed out. It might be nice to run an aftermarket s/c with the stock ECM, but honestly you can tune it just fine without dealing with those settings.
    Apr 2004
    OK, we got it running. The Edelbrock tune was garbage and messed up the ECM. We flushed the ECM and got a stock tune in and then went from there.
    OK, some idle issues, surges when cold (no AC) see 001. Start the car, it hits 650 and idles smoothly. I give a little gas and clutch to back out of garage and clutch in and LET THE SURGING BEGIN. It will actually die if the AC is on.
    Also, it is dieseling when I shut it off. Any hints on what we can do to stop it?
    Elmer
  1. camaro 2010 e-force
    By franckrem in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2010, 08:00 AM
  2. G-Force
    By killerbee in forum General (Diesel)
    Last Post: December 27th, 2008, 12:05 PM
  3. Force regeneration with EFILive?
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 10th, 2008, 09:39 AM
  4. force motor current
    By 69camaro5speed in forum General
    Last Post: December 8th, 2006, 10:47 AM
  5. Force motor current
    By 87gmc in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 16th, 2005, 01:58 PM
