Does this look right. I can't get the pid for the Lambda error to work. It just comes up with a Red X. Any help would awesome. I have a allot of new gray hairs trying to figure this out.
Justin
#NGK WBO2
*CLC-00-026
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 9.0 16.0 .1 "{EXT.AD1}*1.4+9"
*CLC-00-027
factor 0.62 1.10 .0 "{CALC.NGK_AFR}/{E38.AFRATIO_DMA}"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.AFR_NGK F001 CLC-00-026 "AFR,V" O2-Wide "Wide Band AFR 1 - NGK"
CALC.Lambda_Err F002 CLC-00-027 factor O2-wide "Lambda Error"
