I am not trying to argue but to understand what you are saying.
Isn't the output voltage the output voltage always and 12.:1 AF is always 12:1. So if my meter is reporting a 2.14v then it is always reporting a 12:1 A/F ratio. So the pid I am setting up will divide my meters A/F by the Commanded A/F and give my the lambda for that cell. example, I have 13:1 A/F and my commanded is 14.22:1 so my lambda reading would be .91 in that cell. If I change my stoich to 14.44 then my meter is still showing me that I am running 13:1 but not it is dividing it by 14.44:1 which would give me a lambda of .90. The reason I do this is that I can use my Lambda errror through the entire VE and not have to worry about where I go into PE at. When my commanded changes to 12.7:1 it should pick that up. That is what I am trying to write the pid for, but it does not seem to be working and I am not sure why. Here is a copy of the .txt file.
#NGK WBO2
*CLC-00-026
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 9.0 16.0 .1 "{EXT.AD1}*1.4+9"
*CLC-00-027
factor 0.62 1.10 .0 "{CALC.NGK_AFR}/{E38.AFRATIO_DMA}"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.AFR_NGK F001 CLC-00-026 "AFR,V" O2-Wide "Wide Band AFR 1 - NGK"
CALC.Lambda_Err F002 CLC-00-027 factor O2-wide "Lambda Error"
