As the title states I can not find GM.E35DSP5_DMA or GM.E35DSP5V_DMA in the list of PIDs. I shift+F2 to validate the PID's and still nothing. I am running Verison 7.5.6 (build 130). Any help would be greatly appreciated.
Nevermind I got it. Had to reinstall the Scan tune software and boom there they were in the list.
I am having the same issue, i can only view the DSP5 PID's in flashscan V2. I would like to read these DSP5 PID's in the V7.5 scan tool, but they are x'd out, i have had tried many times of validating but still no luck. is it possible you can only read these DSP5 PID in the flashscan V2 but not the V7.5 scan tool? I'm running version 7.5.6 (build 130). LMM application.
If they have red X thru them, just try to log them anyway.
Make sure you are looking for the PID's listed in my first post. They are the only ones that work for the lmm. At first mine was not there but after I reinstalled the software they showed up. In parenthesis beside the correct PID's will have lbz/lmm. Once you get them double click on the voltage and tune PID and then make sure you push the yellow button down at the bottom to actually see these values change as you turn the knob.
Ok, thanks. i will try uninstallilng and reinstalling the V7.5 software tonight
joecar, i have tried to log them anyways, they still are inactive so no data
Thanks, reinstalling V7.5, the DSP5 LMM PID's showed up. Anyone know where find some EGT's that work for LMM? In PID file 'Duramax_LBZ_Imperial', EGT1;EGT1A;EGT2A, all have incorrect values.
