Results 1 to 4 of 4
Thread: Dropping a marker into a BBL file?
    Member JAY4SPEED's Avatar
    Mar 2007
    Question Dropping a marker into a BBL file?
    Sorry if I missed this somewhere. Is there a way to drop a marker into the file while doing a BBL? Is there a V2 key shortcut for this?
    As an example, if I'm trying to diagnose a specific condition while BBL data logging, when the vehicle displays the intermittent condition is there a key to press on the V2 that will mark the file (drop a bookmark) close to that area to find it easier later on when reviewing the log file?
    Jul 2007
    Press any of the function keys on the V2 <F1> sets note 2, <F2> sets note 2 etc. Use the <CNTRL>-<F1> for note 5 and so on. You can reuse the notes with no real detriment unless you actually want to put comments in later. I usually just hit <F1> and take a mental note of what occurred.
    Simon
    Mar 2007
    Perfect!!! Thank you so much Simon, once again your help is greatly appreciated.
    Jul 2007
    Oops, I just realised I used "Note 2" twice :p.... <F1> sets Note "1", <F2> sets Note "2" etc.....
    Glad to help.
    Simon
  1. What is BBL?
    By FeetDry in forum FlashScan V2 BB Logging
    Last Post: June 17th, 2010, 06:55 AM
  2. Off Throttle Dropping Through Idle
    By SOMhaveit in forum Gen III V8 Specific
    Last Post: August 24th, 2009, 06:49 AM
  3. how to bbl
    By nchristian in forum Black Box Logging
    Last Post: June 15th, 2009, 08:57 AM
  4. bbl log file say chanel count zero
    By tokymon in forum Black Box Logging
    Last Post: July 6th, 2008, 02:52 PM
  5. BBL - Take Two
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: December 18th, 2007, 02:56 PM
