Results 1 to 6 of 6
Thread: Need 2006 SSR M6 stock file
    Default Need 2006 SSR M6 stock file
    I hope that someone can provide a stock M6 file from a 2006 SSR.
    Aug 2010
    Hello Xman,
    Is the LS2/T56 currently in an '06 SSR, or is it from an SSR - being transplanted ?
    Regards,
    Taz
    Goes in a 91 vette. I still need this tune file due to issues with cruise control.
    Quote Originally Posted by Taz View Post
    Hello Xman,
    Regards,
    Taz
    Aug 2010
    Was hoping it was for a swap. Early LS2 engines (’05 - ’06) were often Gen III variants (24x CKP / 1x CMP). The LS2 wasn’t universally a Gen IV (58x CKP / 4x CMP) until ’07. All ’05 Corvette LS2 engines and all ‘05 - ‘06 GTO LS2 engines were Gen III.
    I’m not 100% positive all ’05 - ’06 SSR LS2 engines were Gen III variants - but some definitely were. All of the above used the E40 PCM - not one of my favourites.
    I mention this, as I have done previous conversions using the ’05 Corvette LS2, but controlled by an LS1-B PCM. This made integrating PCM controlled A/C and Cruise Control much easier. It also allowed using either DBW or DBC - depending on the vehicle, or customer preference. Also, the LS1-B style PCM is much easier to tune (for me anyway !).
    As a quick check - the CKP sensor on Gen III engines is black, on Gen IV engines it is greyish. To be 100% sure, I’d still pull the oil pan and look - as you know the 24x and 58x reluctor rings are very distinctive.
    Just a possible option ……
    Regards,
    Taz
    All Good info, but, this is not my swap. I do a lot of them but this is another shop that I support with tuning. He already built a custom harness for the E40 and yes this is a 24x.
    I agree he could have made his life easier with a LS1-B PCM. He did not ask for advice on selection.
    I can use HP tuners because there is a stock 2005 M6 SSR file available. I would rather not because I would have to pay for it and I already have the license with my Workshop EFILIVE V2.
    I still need the EFIlive SSR M6 2006 tune file to finish the job for his project. Anybody?
    Aug 2010
    OK … understand fully now.
    Sorry, don’t have an ’06 SSR tune - not many sold in Canada - never had one in the shop.
    Hopefully someone has one they’ll share.
    As a fall back plan, there are ’06 GTO LS2 manual tunes on the Holdencrazy site.
    • two engine tunes from manual trans cars (OS# 12603159 and OS# 12604792)
    These should work OK in a swap application - obviously you would have to confirm the E40 pinouts are the same. Given that your customer built the harness, if it came down to it, moving a couple of pins is straight forward.
    Good luck …..
    Regards,
    Taz
  1. I need stock file of vette c6 2006 12614682
    By odd boy in forum Petrol / Gas
    Last Post: July 28th, 2010, 02:04 AM
  2. Need Stock Tune for 2006 C6 Z06
    By E.A. in forum E37, E38 & E67 PFI ECM's
    Last Post: September 24th, 2008, 03:41 AM
  3. Looking for a stock OS 12605732, 2006 Vette
    By CTH in forum E37, E38 & E67 PFI ECM's
    Last Post: August 30th, 2008, 12:09 AM
  4. 2006 Vette MN6 stock tune?
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2008, 01:28 PM
  5. I wont stock PCM for corvette C6 2006
    By hassan in forum Gen III V8 Specific
    Last Post: March 26th, 2007, 05:07 AM
