Results 1 to 3 of 3
Thread: P0299 code
    Aug 2010
    Default P0299 code
    I seem to keep throwing the p0299 code on my lly which sends it into limp mode and I was wondering if there was any way to fix that in the tables?
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    P0299 is set when the truck cannot reach it's desired boost number. This may be because the desired boost is set too high, or because there's an issue with the induction or vane actuation system causing the turbocharging system to lag behind the desired boost level. If you want to send the tune you're running in the truck to me (Nick@duramaxtuner.com) I'll take a look and see if I can decipher if
    Nick
    Return to factory tuning to see if it goes away. This will help determine if the problem is hardware related or not.
    If it is tuning related, it is possible that your allowable vane position can't support the requested boost numbers.
    Custom Tuning Services
  1. Code P062F and Code P0633 Help
    By Airtime in forum General (Diesel)
    Last Post: September 28th, 2009, 01:57 AM
  2. code p0500
    By brown bear in forum Duramax LB7
    Last Post: June 15th, 2009, 05:07 PM
  3. Activation Code
    By run8nova in forum FlashScan V2
    Last Post: May 3rd, 2008, 10:00 AM
  4. Code PO101
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: April 27th, 2007, 05:04 AM
  5. Mcrat 20 20 and p0101 p0299
    By Madspeed in forum Duramax LLY
    Last Post: March 25th, 2007, 03:32 AM
