Results 1 to 6 of 6
Thread: loading a tune into flashscan v2
    Jun 2010
    Default loading a tune into flashscan v2
    hey guy's,
    i recently purchased a flashscanv2.for sure a rookie here.after modifying a calibration,how can i load it to the flashscan and flash the pcm with just the flashscan?sorry if this post is not in the right place.
    thanks in advance
    Nov 2006
    Format the SD card or internal memory with the V2>
    Save the .tun as .ctd>
    Drag and drop the .ctd into the Read folder of the SD card or internal memory of the V2 with EFILive Explorer.
    LC-1 WBO2
    First install the latest V7 and V8 software (see below) and update V2 firmware to 2.6.40 ... then do what mr.prick said.
    http://download.efilive.com/Software....132_Setup.exe
    http://download.efilive.com/Software....113_Setup.exe
    Jun 2010
    thanks for the fast replies,
    i updated to the newest version of software,and followed mr.prick's directions.but,i get an error:0502 script file not found.i see the flash in the flashscan,but i get that error when i attempt to program.
    Use the S&T software to select the PCM/ECM for BBF, see pic.
Name:	S&T - Black Box Settings - Tune Settings.png
    Jun 2010
    hey,
    i got it!!thank you both for taking the time to help me out.
    thanks
  1. Odd problem with loading a tune
    By Telco in forum Gen IV V8 Specific
    Last Post: November 27th, 2013, 10:24 AM
  2. little help loading tune
    By aaronr in forum Black Box Logging
    Last Post: July 4th, 2010, 08:22 AM
  3. Loading tune with bench harness?
    By JoakimMD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2009, 04:57 AM
  4. Trouble loading DSP5 Tune
    By Dmaxx 02 in forum Duramax LB7
    Last Post: September 14th, 2009, 07:12 PM
  5. Latest tune -1 loading
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: March 8th, 2005, 06:38 PM
