Results 1 to 9 of 9
Thread: Different Laptops
    May 2010
    Default Different Laptops
    I am going to be borrowing my friend's EFI live setup and I am wondering if it is possible to use my laptop rather than his? If so, what do I have to do in order for this to work? Also, the last time that we tried to connect my PCM to the Software it kept saying that it couldn't connect or PCM was locked. I spoke to ECS and they told me they never locked it. We do have available credit left so we can connect the PCM to software. I really appreciate the help. Thanks. I thought I have read that it is possible.
    What do I need to make it work on my laptop and why isn’t it connecting?
    Lifetime Member tokymon's Avatar
    Apr 2008
    should work i use 2 diffrent computers to tune (a desk top and laptop)
    just install efi live and should be all set to go
    97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
    stock sucks
    Oct 2004
    Sometimes if you attempt to read an ECM without setting the correct controller selection you may get a locked message. For instance if you have an LLY Duramax and left the controller selection on LS1.
    If you have the correct controller selected before doing the read and still get a locked message chances are very high that the ECM has in fact been locked somewhere along the way.
    Andrew
    EFILive Crew
    May 2010
    Default Great
    Good to hear. Also, I haven't gotten my hands on the software yet(this afternoon), but is this as simple as plugging it in, or are there some kind of steps I must do? Any links?
    Latest software see here.
    If you have V1 you need only V7.
    If you have V2 you need both V7 and V8.
    Phil,
    Just plug in.
    And welcome to the forum...
    Quote Originally Posted by philsz06 View Post
    Also try checking the "Try Alt Keys" check box before attempting to read the ECM. That will cause EFILive to try additional keys that may unlock it.
    Apr 2010
    I have a similar question, my best bud is going to be borrowing my efi live to help setup his car until we tune it. If I unlock his vin using my computer and then let him borrow efi live.... when he installs the software on his computer does he have to register it using my info or can he leave the software unregistered?
    I have no problem letting him borrow it but I really did not want to register the software on his laptop with my information since this is a one time deal.
    Oct 2004
    He can just enter the details from your blue registration card. All the licensing is done within the FlashScan interface itself, so no issue running software on multiple computers.
    Andrew
    EFILive Crew
  1. Logging Tip For Newer Laptops
    By swingtan in forum General
    Last Post: October 18th, 2008, 03:06 AM
  2. 2 98 F-Bodys, 2 Laptops, 2 V2's, none will connect
    By eurospec1 in forum FlashScan V2
    Last Post: December 4th, 2007, 08:05 AM
