Just received my 3B1 Tech Edge wideband and was trying to hook it up through the serial port. From what I can tell, the the V1 pinout on the "bench harness" tutorial serial pins do not match what we have on the V2 cable doing a continuity check.
From the attached diagrams it appears that I need to get:
Techedge RJ45 EFI Live
Pin 5 (Ground) Pin 2 (Ground)
Pin 3 (Tx) Pin 5 (Signal)
Does this sound right??
Thanks,
Matt
