When i go to do a crank relean it gives me error. Yes the truck temp is above 105* Does this mean the sensor is bad?? I'm not getting any codes. This sensor under the starter?
2006 Trailblazer SS
Twin Turbo 67 Chevy Truck
SOLD Truck 2002 Chevy kb turbo t70 5.7l
Was that a transpose with the temp? It should be at or above 150°.
Were you getting a P1336 code before? Is it gone now? Hook up the scan tool & pull the codes to see what you get.
