Good job
Do you know what caused your V2 to smoke...? Was it a missing ground connection...?
The PPL (purple) wire is the serial bus...
do this:
- remove all modules from the serial bus (important),
- check for continuity between OBD2 port pin 2 and the serial bus pin at each module's connector (should be the same color, PPL),
- install all modules back onto the serial bus,
- in the scantool goto the OBD tab and see if all the modules get reported.
