Results 1 to 3 of 3
Thread: No DTC's in log file
    Jul 2009
    Default No DTC's in log file
    Managed to get my V2 logging OK although have very little idea of what most of the numbers mean! However, I know my engine is throwing a few codes because when the V2 is connected via the OBDII you can read them and when it's connected in pass-through mode, it brings up a whole list (it's a transplant into a kit-car so most of them are for stuff I've ripped out, like EVAP, A/C etc.).
    However, if I load a log file that I obtained through BBL, it says "No DTC's stored in logfile" (or similar) - is this something that could be fixed in the future or have I set it up wrong?
    Default Saving DTC's in log file
    For passthru connection of scantool to vehicle:
    in scantool, go Edit->Properties->Logging and under Auto-Save Meta Data check DTC's... and leave the others unchecked.
    For BBL:
    can't do it... you have to go F3 Diagnostics -> F4 Record All Diags and numbered .txt file will be saved containing any DTC's.
    Jul 2009
    Ah, OK, not to worry then. Perhaps this is something they'll release in the future. I've deleted most of them anyway - still getting P0463 (fuel level sensor 1 circuit high voltage) - think I can delete this assuming it refers to the original tank (which I haven't got)
  1. Lost log file
    By FeetDry in forum FlashScan V2 BB Logging
    Last Post: July 13th, 2010, 12:08 PM
  2. Excel DTC File from Husker Diesel....
    By husker_diesel in forum General (Diesel)
    Last Post: June 16th, 2009, 03:31 AM
  3. Cannot start new Log file
    By Gordy M in forum Gen III V8 Specific
    Last Post: August 31st, 2007, 12:46 AM
  4. Opening a log file?
    By jfpilla in forum General
    Last Post: June 27th, 2007, 02:24 PM
  5. Would someone be willing to look at a log file?
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: May 6th, 2007, 09:47 AM
