Just took the kit-car (Cobra) out on a brief run and logged the results. The first file, LS1A_0017.efi was a run up the road with some brief full throttle squirts (although I notice the TP doesn't get above 97%). The second file was a rolling drag start (only because another car started coming towards me and I had to set off before the logging had started).
I don't have wideband O2 and apart from the bits I've removed (EVAP/AIR/AC) etc. the engine is a stock LS1 (with LS6 intake, I think) running a T56. I have CATS but no rear O2 (have a Baker module installed that simulates them, apparently)
Thanks,
spandit
